• PC-DMIS Blade now supports a floating license
• You can now send measurement results to the Q-DAS Configurator for statistical analysis.
• You can now see that the SQUARE + TIPARC method for leading edge and trailing edge thickness measurements now provides consistent results. PCDMIS Blade now uses a nominal flat edge surface normal and selected best fit to orient the nominal flat edge relative to the measured curve. Also, the OFFSETFLAT method now uses the nominal flat edge surface normal combined with the selected best fit.
• Blade can now do ZONEFORM in 11 places.
What's Fixed
• You no longer get a looping leading edge when you use probe compensation. See BRK-1106.
• You now get correct results when you use Concave-only and Convex-only best fit. See BRK-1053.
• You can now see that the “Fit to middle of tolerance zone” feature works correctly for all blade sections. See BRK-1131
• You no longer get the “Attempted an unsupported operation” error message when you open a Flavor file in German version of PC-DMIS Blade. See BRK1168.
