How do I measure the angle between a cone and a circle / cylinder?
Thank you
Thank you
Construct a line between the center of the part and the larger hole, and a line between the large hole and the smaller hole. Then measure the angle between those two lines.
You will probably have to do the math as it will be giving the the wrong side of the angle at 75.5
You change the To/From option, or the Supplementary check box to get the correct value - no maths required.
Sometimes the Demon still hates you though!
| © 2026 Hexagon AB and/or its subsidiaries. | Privacy Policy | Cloud Services Agreement |
