I am having the same, if not very similar, issue with Datapage+. My CMM program runtimes are 3-4 times longer when ran with stats on (a program that normally runs 20 mins could take an hour or longer, my 1 hour programs now take 3-4 hours). Can someone explain how to setup this special schema on the database side? I am trying to avoid having to change to an external command if I can help it.
Are you using the offline file via the Stats/On command?
No, we use online connection. My predecessor setup all of the programs with an online connection to DataPage. I have tested a couple programs with swapping to an offline file and having the Data Importer sweep the files into the database. It does work and does not slow down the programs, but for the same reason I don't want to swap to an external command (we have thousands of programs I would have to update) I would prefer to setup a schema on the database to help fix the connection. I just don't know how to do that yet.
Yeah that would be the problem. That function of the Stats/On database direct connection command hasn't really had much support in a long time as we switched to the offline file method a long time ago. Let me also recommend if you ever switch, do not use the External Command, just check the box for the Offline in the Stats/On command.
I guess for now I will just dedicate some portion of my day to changing over all programs to create an offline file. Do you know of a way to change the default location where it creates the offline file?
At the end of the routine. Add a Stats/Off command, followed by a Stats/Transfer command, and you can send it wherever you like.
| © 2026 Hexagon AB and/or its subsidiaries. | Privacy Policy | Cloud Services Agreement |
