You must qualify the same stylus twice. You can use QualifyTool to calibrate the disc diameter & CALPLA to calibrate the bottom face.
The reason is, the deflection for the disc probe diameter is zero in Z & deflection for the disc probe face is zero in X & Y.
I've never done it that way, but I'm told it works.
Lee,
I'd be concerned using a planar probe (bottom of disk) to find the 'very top of a pointy, sharp edge in the +Z'.
It is not a Quindos issue, but rather a 'metrology issue'.... if your tolerances are tight, then I would hesitate to use the bottom of a disk probe to do such. The CMM disk not recognize where on the bottom of the disk/planar probe that the point is taken, so if the bottom of the disk is not orthogonal to your Z, then introducing a cosine error.
| © 2026 Hexagon AB and/or its subsidiaries. | Privacy Policy | Cloud Services Agreement |
