Implementation of DIN5459 for datum system creation in general with Quindos and its validation in measurement comparison to Zeiss Calypso software
Hello Quindos World,
as I have not found any Quindos user with larger experience on that topic yet, I am very interested in experiences and opinions on this topic.
We are working in automotive industry and have a larger group of customers using Zeiss Calypso software. Many of them using the inbuilt function "Datum creation according to DIN5459, with tangential elements"
As far as I understand this option creates datum systems which uses "tangential" elements for position and direction of the datum system.
At our place (at least until now) it was common to use Gauss (LSQ) elements with the "BLDCSY" command for creation of the datum system. And of the colleagues I know of at other companies I also only saw them using Gauss (LSQ) elements.
This difference in datum creation leads to measurement differences (e.g. position, coaxiality etc.) with customers on same part.
So my questions would be :
- Any of you guys had this kind of discussion internally or with customers using Calypso before and/or is regularly using datum creation according to DIN5459 where the drawing implies ?
- Any of you guys regularly using the "BuildDatumSystem" command and have any experiences how it compares to the mentioned option in Calypso ?
- I guess as it uses tangential elements scanning and filtering is a must ?
as more customers seem to use it I need to gain more knowledge on that topic and how to implement it in Quindos accordingly.
  • Hello, From a factory point of view, we do not have experience of the Calypso solution when compared to the Quindos solution.
    I have copied the Calypso menu into the ticket.
    Based on my observations & comparing the options available in BuildDatumSystem, you should be able to correlate the two softwares without too many problems.
    If you have a specific problem with the corelation Calypso / Quindos & can supply both programs then please send them to the hotline (hotline.quindos@hexagon.com) for analysis.
    BTW, based on the Quindos screenshot, it looks like we have "endless" calculation types, so a correlation should be possible.
